I LOST THE SURVEY PROCESING SHOW DETAILS OPTION
When I press this option nothing happens. pop-up screen does not appear.
Any idea how to make it reappear?
Thanks.
  • The simplest way to correct this is to delete examples.ucf .  Then go into your Windows Control Panel>Programs and Features and run a "repair" on InRoads.
  • Thank you very much Jacquelyn.
    I also tried this but it has not been the solution.
    A new examples.ucf has been created but has not resolve the issue.
    I think the problem is in "Bentley-Civil-Metric". If I change this file  the problem seems to be solved.
    Thanks.
  • In that case, I would try deleting the Bentley-Civil-Metric.pcf located in C:\ProgramData\Bentley\MicroStation V8i (SELECTseries)\WorkSpace\Projects\Examples.
    You can replace it with the file I have attached.
