I want to ask two questions regarding Place Plane Note in Inroads SS2 Is there is a way to add new Data to the inserts like Radius or Detla Angle ?Is there is a way to remove the arrow and to have only straight line from the note as seen in the picture attached ?Thank You
Only the values contained in the "Computed Values" are available in this command.
You can disable the arrow by setting the Leader Terminator to "None" on the Settings dialog.
Answer Verified By: Mahmoud Riyad
