Sorry , but I have another question can we have an annotation on the profile that show the elevation and the station of two intersecting alignment .
I recommend you create Cogo Points at the intersection locations. Then you can use the Points to Profile command to project the cogo points onto a profile window that is owned by a specified horizontal alignment. The points are displayed in profiles belonging to a specified profile set (as long as the station and elevation fall within the bounds of the profile). You can then use the Drafting>Place Profile Note command to annotate the station and elevation of these points.
Actually sometimes it is difficult to detect the intersection locations , is there is another way and can we import the alignment as feature and using crossing feature in profiles
Yes, that will work as well.
When I tried to do as crossing feature it keeps showing many points and I wasn't able to get it in correct way.
Could you please provide with the steps do it correctly ?
Thank you
Here are some instructions:
communities.bentley.com/.../problems-annotating-cross-sections.aspx
