I am trying to add labels to an alignment. I am new to InRoads SS3 and I am trying to get a handle on some of the configurations. We have it setup thru Preferences to label the alignment stations and tick marks, and the curve data, but I cannot figure out how to label the tangent segments with a bearing. Is this done thru the Preference Manager or a dgnlib file?
Hi Dalek
If I understand your question correctly, follow these steps: From the main menu bar select Setting>Design File>Angle Readout, Direction Mode for Bearing and you can also modify your Format (be sure to select OK). As you select OK you will see the change.
Sanders
Thanks for the reply, however I am trying to make InRoads label the alignment automatically when I create the alignment. As I create the alignment it will label the stations and PC & PT labels, but it will not label the bearing along the tangent segments.
I did verify that the settings are correct in Angle Readout.
Dalek
Dale
Civil 3D 2018, ORD 2019 Rel 1, InRoads SS3
Drug kicking and screaming into the world of InRoads & ORD!!
