How do I merge Storm & Sanitary SDB files or content?
I posted this recently under a question that had been marked "answered"...so I'm not sure if people see my post...and therefore I'm posting anew.  I apologize if this is being seen twice.
The thread I had tried to respond to discussed when to use more than one SDB file, which to me implies that using separate SDB files might be a common workflow.  But since two can't be opened at once, how does one then combine the SDBs later so that all info can be displayed.  For example, we are using one SDB to house existing utilities on a densely-utilitied urban project...and another to house our proposed storm drainage, sanitary sewer, and relocated utilities (gas, water, etc.).  But how then do we display both existing and proposed utilities in the same (drainage) profile?
Thanks for any guidance,
Steve
  • Thanks for your thoughts Kate.  My research indicates back-saving to Access 95 is a difficult proposition.  I have tracked down and purchased a legacy version of Microsoft Office w/ Access 95.  I'll receive that later this week and then attempt to combine the SDBs in Access.  I'm hoping it's that simple - we'll see!
  • Well, remarkably it looks like we have been able to stitch together our SDBs using Microsoft Access 95!  I'm not sure if we're allowed to acknowledge vendors on Be Communities, but I located the vendor oldsoftware.com and purchased a copy of Microsoft Office 95 from them - it was delivered within 3 days of placing the order.  I installed it on a 2006-era personal laptop of mine - it installed with no issues (I did "custom install" and only installed Microsoft Access, not the rest of the Office suite).
    We had 3 SDBs we needed to combine to one....but it would seem to be the same workflow for 2 SDBs or more:  Open 2 instances of Access at one time, open one SDB in each.  Copy info one Table at a time from SDB "A" to SDB "B".  If you have more than 2 to combine, close SDB "A", open SDB "C" and copy from "C" to "B".  Repeat as needed.  I'm attaching a screenshot describing the process for copying a table (Pipes, Manholes, etc).
    Starting Monday, we are going to work with our new combined SDB to make sure it is operating properly, but early indications are it is going to work.  If it does, and it is as easy to combine them as it seems....it does open the door to working with multiple SDBs during development so long as you retain a legacy copy of Access 95 on hand for the combining.
  • Merging SDBs has become an important part of our workflows. We're using Office 2007 and can open the SDBs with MS Access and copy tables (Access 95 not required). It's important to NOT allow Access to upgrade the database to a newer format (counter to what it recommends when prompted). Also remember to copy/append the records in the IDs table. One word of caution when using Access to copy/append tables; duplicate IDs when merged can become a serious problem. It's important for the users to strategically name all elements to avoid duplicate IDs after the merge.
    I've developed an in-house tool to more efficiently merge the SDBs using VBA, eliminating the need to use Access. I'd highly recommend reaching out to a developer to create a tool to automate the process, for sake of both efficiency and quality. We're merging up to 20 SDBs at a time on large projects in less than a minute.
  • Thanks for the insight, Chris...I've always worked in a single SDB so we found ourselves embarking on the multiple SDBs without a good strategy, whereas you seem to have that covered with your Office 2007 and VBA automation.
    FYI we have Office 2010 and attempts to manipulate (without upgrading) were not successful for us, though perhaps we didn't pursue it thoroughly enough.  Do beware if you transition from 2007 to 2010 you may find roadblocks.
