Civil models to Bentley Navigator - Civil Solids to Bentley Solids
I am trying to figure out how to convert my corridor in Open Roads to Bentley solids so I can split them up into usable components before bringing them into Bentley Navigator. Once in Navigator I need to do a schedule animation for construction staging. Is there a way to do this? I can use the split solids tool on the corridor but it does not retain both sides (yes I have split solids checked).
Is there some other way to split these large corridors up in Navigator or Microstation? If someone needs to show construction staging or really any sub-component of on of these linear corridors we we need a way to break them up after design. Please tell me there is a way to do this and I am just missing the obvious solution.
Cheers,
Terry
Parents Reply
  • So I have only done this once so far.... I am tight on time this morning but will do it again later today (and do a screen record). That said, If I recall the directions they had either were wrong or I interpreted them wrong the first couple times. Try making a copy of your 3D model containing your corridor, reference in your 2D clipping shapes ( make sure they are 2D and shapes not complex strings). Then run the macro from within the file that has the corridor live.
    It has been a few days since I got it to work and my memory is a little sketchy since I was up late trying it... but I think this is what got it done.
    Cheers,
    Terry
