When I create a corridor some features where not visible in the plan view. Strange thing is, when I edit this feature in the template editor, to a feature definition which is visible and change this feature back to the first one, it is visible (see video).
Is it also possible to make this feature visible directly in the 2D plan view?
Regards Louis
Check the Feature Definition 'Linear Default Settings' - Is the 'Create Template Geometry' setting set to 'True' for that feature?
Answer Verified By: Louis van Amerongen
For anyone not sure where the 'Linear Default Settings" are within Microstation, this version has pictures and an explanation:
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/15953/roadway-linear-feature-does-not-show-in-plan-view
