Is there a way in SS3 to stroke linear features by Feature- rather than having to use a global setting in the configuration?
Jeremy Keller
You have the config variable CIVIL_DEFAULT_LINEAR_STROKING to set the overall linear stroking tolerance. Say you want the overall tolerance set to 10, but you have a handful of features that you want set to 5. Is there a way to leave the overall set to 10 and set that handful of others to 5?
Jeremy
Hello Jeremy,
It is not really clear to which area and settings you exactly refer. Can you please elaborate more on the question you are asking, if possible describe your workflow and add screenshots or example files, so that we can try and help you find an answer.
Thanks.
Henk
