Hi
I am trying to insert a Civil Cell junction, but the program crashes every time.
I am using 2d seed file with 3d reference file with terrain and geometry.
Could these error become because of the chosen geometry from reference? It is no problem with the corridor and ref. geometry thought.
I am using PowerCivil for Denmark V8i vers. 08.11.09.497
Sigfus
Can you forward me your data? In theory you can place the cell on referenced geometry.
I have seen where abrupt change in geometry( i.e. an EoP that uses a point control suddenly extends outward between stations) will cause a failure if that change is at the cell placement point. In this case the cell can be placed by deactivating point control and re activating after placement. This is good to see all the dynamics and rules update moving everything into the correct position
Michael Barkasi
Application Engineer
Reality Modeling
Another idea is to open the DGNLIB that contains the civil cell. I have previously experienced a crash when the civil cell is not "Valid for Placement". The crash I saw happened immediately when I clicked on the Place Civil Cell Tool.
You can read more about the Valid for Placement setting at the following link:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/17107.civil-cell-valid-for-placement-setting.aspx
Answer Verified By: Sigfus Jonsson
