hello,in the past (criteria) when we was running earthworks with the inp file, we write in the inp file to consider stripping.look in the file attached.we want to get those results in the report:fill = C+Dcut = Astripping = B+Dhow we can get these in the component quantities ?
There is way to control the earthworks quantities thanks.
HI Assaf
Could you let us know which product and version you are using please ?
Simon Pegg B.Eng (Hons) I.Eng
Bentley Product Advantage Group
Civil Support Manager
We are using Microstation 08.11.09.578 And Geopak 08.11.09.674.
Thanks.
You can use Unsuitable Material by Station feature available in End-Area Volumes tool. It will work as you need when the depth of stripping is constant in a single cross-section.
Best,
Adam
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
We are using the corridor modeling, when we calculate report using the Corridor Reports -> Corridor components quantities.
There is a way to control the components and to tell to each component how to behave (if the component is fill or cur) ?
We would like to get report of the corridor.
Assaf.
Hi Asaf,
As far as I know, there are no fill/cut components available (yet).
Regards, Krzysztof
