Good Morning,
I have a project where we are overlaying the roadway without milling, we are overlaying with a thickness of 7.5" on top of ex pavement. I would like to run a template that will run along the existing horizontal/vertical and will run 7.5" above the REOP or the LEOP (12' L/R of horizontal alignment). The 7.5" will very from LEOP to REOP. The top of the template will be 2% cross slope L/R and the bottom will follow ex ground. I would then like the template to create the vertical alignment for me. I imagine the overlay/milling template will work for this but doesn't the milling template work from the ex ground down? Any insight on how to accomplish this will be greatly appreciated.
it
I came across a few slides that may help in your research. There are a few overlay component slides at the end that could help you.
Answer Verified By: Chuck K.
Templates 202.pptx
