Having an issue with the labeler labeling all cross sections properly. About 90% of the sections are labeled and it seems that the other 10% of labels show up just not where they should be...i.e. STA. 11+00.00 will show its respective label w/ elev. and offset but it will also show the label for STA. 10+00.00 with the added elevation of STA. 10+00.00 and STA. 11+00.00. (shown in first picture of PDF) Some cross section will have a few labels but not all specified and others will be completely blank.
I've already tried creating a new .xlp and a new cross section .dgn to no avail. I've used this program before with no issues. Since last using without issues my comp has been upgraded to Windows 7, V8i SS3 v. 08.11.09.459 and Geopak V8i SS2 v. 08.11.07.615.
Any and all help resolving this issue is appreciated.
check what is the actual vertical distance between the xs cells? it should not be below the default 500'
Answer Verified By: Danny G
Thank you! Problem fixed. I was unaware of that default.
