Openroads Corridor Template - Horizontal Feature Constraint Target Survey Feature Definition (Inroads 08.11.09.722
If I have an existing conditions survey that was assembled using terrestrial point data with point codes and feature definitions (to create point list linear features and an existing terrain model), how can I target the resulting linear features (E_Road_Edge_Pave) in the corridor template points using the Horizontal Feature Constraint option??  The existing surface is referenced into the corridor dgn.  Two things (at least) I don't understand about this situation.  1: Can I target feature definitions that are located in a referenced civil model??  2:  Can I target Survey Feature definitions??
Thanks in advance!!
