I have added a picture below of what I am talking about. How do I remove the "ghost" too box that pops up when I use the Element Selection Tool? It pops up every time I select and element and don't move. It is especially annoying when I need to lengthen a line to a specific length and I click on the end and I can’t time in the length under the Accudraw. Please help. Thanks
the popup doesn't come from MicroStation, so it's probably not possible to switch it off using MicroStation configuration.
Do you use some other application? It looks like some civil app.
With regards,
Jan
I am running GeoPak Road
I have no experience with GeoPak Road, so I am not able to provide you more than general advice to check if a GeoPak Road preferences or configuration contain the popup menu display setting.
You can also try to switch off Markers switch in View Attributes, but it's MicroStation switch so I don't know if GeoPak Road will reflect this setting.
That is the context tool box that is part of the SS3 releases of the civil products. The wiki article below details how to disable it.
Context Tool Box: Turn on/Turn Off
Answer Verified By: Jason Walsh
