Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
OpenRoads | OpenSite
OpenRoads | OpenSite Forum
PROBLEMS WITH A TEMPLATE THAT TIES INTO THE TERRAIN AT THE LEFT OF WAY LINE
Sign In
State
Verified Answer
Replies
Answers
1 answer
Subscribers
140 subscribers
Views
Users
0 members are here
Offline
Ikasten
over 8 years ago
Hello.
I'm starting with Openroads. PowerCivil SS3.
I'm trying to apply a template to get variable slope not to pass across a line (Geom_ROW).
I am following "Defining End Conditions" Trainning and I have created a template for "A solution That ties into the terrain at the Left of Way line".
But I do not get it to work.
The template´s Test is Ok.
I think I have to make my limit (Geom_ROW) belongs to the terrain model. Is this correct?
But I don´t know how to do that.
The limit (Geom_ROW) is in another Referent and his elevation is zero.
Is posible atach this limit into the terrain model?
What is the correct workflow to do that?
Thank you for yours sugestions.
0
Offline
Jason Walsh
Tue, Oct 14 2014 5:18 AM
Have you added the Geom_ROW Element to the corridor as a Corridor references?
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Reject Answer
Cancel
0
Offline
Ikasten
Wed, Oct 15 2014 4:01 PM
in reply to
Jason Walsh
Yes, Jason. I've done that but I did not get the desired result. Any other suggestion? Thank you.
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
Offline
Adam Wieczorek
Mon, Oct 20 2014 3:42 PM
in reply to
Ikasten
As you use Geom_ROW as End Condition target and not Point Control I would try to set Target Aliasing for that target. Go to Target Aliasing, select Corridor and set a target alias for Geom_ROW. Once you added your Geom_ROW as corridor reference it should be available on the list in Target Aliasing tool.
With OpenRoads you don't need to specify true name for End Condition target. You can simply key-in ROW and then using target aliasing choose real name of ROW geometry, eg. target alias for ROW would be Geom_ROW in your case.
Search this forum for Target Aliasing, you will find interesting posts by Bentley Colleagues.
Adam
Answer Verified By: Ikasten
Cancel
Vote Up
0
Vote Down
Sign in to reply
Reject Answer
Cancel
