OpenRoads import superelevation from file
Has anyone tried to import superelevation from CSV with PowerInroads/Inroads 08.11.09.722?
I created report from my superelevation section (Provided by Bentley CSV report) stored in dgn file. Then I moved to another file and created superelevation section and lines on a base geometry. I want to import previously created  CSV report - but I get no superelevation data and no error message.
Lanes names in DGN file match names in CSV files, same with station format, etc. I can not have that tool worked.
I thought it would be the best way if you changed baseline geometry dgn file and want to copy Superelevation to be based on another geometry (which is basicly the same one)
Adam
