I am using Geopak 08.11.09.722 Civil Tools --> Corridor Modeling to view and create cross sections. Using the view cross section tool, all Microstation meshes, solids, and surfaces in the 3d file appear in the cross section model view. Using the create cross sections tool, none of these show up, only the corridors or terrain models. Is this the correct behavior? How do I get other 3d modeled items, such as 3d Geopak Drainage nodes and pipes to appear in the cut cross sections.
Rick
It must be Geopak specific then. However I was sure that cross-section engine would be the same for all civil products with OpenRoads technology. Do you use Geopak tools to cut cross-sections or new OpenRoads tools?
You are right that this is advertised as one of greatest benfits of the new technology and it was one of reasons that make me migrate to Openroads.
Best,
Adam
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
I am using InRoads SS4 08.11.09.878 and want to know if this issue has been resolved. I am having a similar issue: 3D line strings show up in the dynamic view but not in static cross sections. What is allowable at this point?
