SS3 Power InRoads – Terrain Conflicting Points Report
Question:
I am using the Terrain Conflicting Points Report dialog (please see screen capture below). The conflicts have a padlock which does not allow me to make changes to the elevations from this dialog. When I right click to change the elevations, these options are greyed out. Are property settings for these greyed out options hard coded in the software and cannot be changed or is there a configuration variable or setting that can be set in order to edit the elevations of these points from this dialog instead of having to go back to the original source file to make the edits?
Parents Reply Children
