When I try "Create Terrain From Point Cloud" the process fails. See attached image. The oroginal file is .pts and I imported it in Descartes and got a .pod file that I am now working with. What could be my problem?
To much data. Is it a classified pointcloud if Yes, you should only use the groundpoints. see also: www.youtube.com/watch Regards, CP
