Can't seem to get the field descriptions to show when importing points in OpenRoads SS3
I am currently using Geopak Suite 08.11.09.726 with MicroStation 08.11.09.608.  I've set the Survey Settings File Parsing Description Separator and am using an ASCII comma delimited text file.  I have been doing this without problem for several years in Geopak Survey SS2 - with the smd and other settings.
  • I did test it , and it worked fine the field description , I recommended to reset Survey Settings File Parsing Description Separator, make sure you set the proper delimiter for the field description then reprocess the ascii file, if the issue persist, please send me the files and if you can make a video when you process the ascii file will be a great help. Thanks
  • Not sure I know how to do a video.  I can show you the data separator, linking codes and part of the ascii file used.  Then there is a dgn screen shot of a sign that should say MTL in the description.  I just noticed, why is there a Caution Icon and it saying SIGN Not found in feature definitions?
    15000,3723709.646869,11788680.542665,179.246339,trav\302
    15001,3723851.085168,11788397.427858,167.982915,hs BEG fl
    15002,3723851.382433,11788396.999923,168.226493,BEG bc BEG sw\bc5@conc
    15003,3723853.534677,11788394.094626,168.210145,sw\conc
    15004,3723848.826584,11788390.715772,167.838398,sw\conc
    15005,3723846.793185,11788393.500714,167.781318,END sw bc\bc5
    15006,3723849.996723,11788393.660670,167.907811,gs\mulch
    15007,3723855.808799,11788390.883744,168.254982,BEG fl1
    15008,3723856.069481,11788390.562330,169.079075,BEG wall\clwallcnc8
    15009,3723841.573643,11788387.841492,165.861448,fh
    15010,3723836.990330,11788394.159631,167.743979,wv
    15011,3723837.367515,11788386.547985,167.080874,bc BEG sw\conc
    15012,3723839.447361,11788383.671320,167.173252,sw
    15013,3723834.634243,11788380.174961,166.874308,sw
    15014,3723832.550052,11788383.006090,166.825214,END sw bc\bc5
    15015,3723836.250865,11788382.912144,167.258416,gs\mulch
    15016,3723835.860921,11788383.310213,166.718173,tree\oak4"
    15017,3723828.701346,11788370.400058,164.279737,END wall\clcnc8"
    15018,3723828.118520,11788370.431881,166.719883,BEG step\cnc
    15019,3723823.788406,11788367.342625,166.811192,END step\cnc
    15020,3723823.553710,11788366.706641,164.311422,wall\clwallcnc8
    15021,3723826.567196,11788376.484384,166.283005,sign\mtl
    15022,3723818.095132,11788372.414489,165.879593,bc BEG sw
    15023,3723819.983443,11788369.759296,165.859550,sw\conc
    15024,3723815.100029,11788366.051740,165.621445,sw\conc
    15025,3723813.262606,11788368.765339,165.581031,END sw bc\bc5
    15026,3723812.967093,11788369.285571,165.325118,fl
    15027,3723815.519691,11788368.253442,165.889244,gs\mulch
    15028,3723816.702826,11788368.889213,165.524363,tree\maple12"
    15029,3723817.412557,11788362.668517,165.591206,fl1
    15030,3723798.717999,11788358.198549,164.531092,bc sw
    15031,3723800.858855,11788355.301279,164.579581,sw\conc
  • I do not see anything jump out as to why they are not plotting, could you attach your dataset. the DGN file, the SMD file you used to create your xml file that has you features in them and the XML too. Also attach the ascii file you are importing.
    For more information about the Road and Site design tools, visit the Road and Site design WIKI at: http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
  • Please download and review this file. specially chapter 9
    https://communities.bentley.com/products/road___site_design/m/road_and_site_design_gallery/270315
