<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>SS3-OpenRoads-Civil Standards&amp;gt;Project Settings&amp;gt;Survey</title><link>https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/102079/ss3-openroads-civil-standards-project-settings-survey</link><description>We are having a problem reading the Civil Standards&amp;gt;Project Settings&amp;gt;Survey&amp;gt;GDOT setting from our ProjectSettings.DGNLIB. Our seed file has somehow gotten a ‘Setting’ entry and all it will read is this setting and we are unable to delete this setting</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: SS3-OpenRoads-Civil Standards&gt;Project Settings&gt;Survey</title><link>https://communities.bentley.com/thread/304001?ContentTypeID=1</link><pubDate>Mon, 27 Oct 2014 14:08:30 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:c47c39d3-43c1-4623-90e0-b4ada3753761</guid><dc:creator>Kevin McDonald</dc:creator><description>We did find a problem where the program assigned &amp;quot;Settings&amp;quot; instead of copying in the correct settings from the DGNLIB.  This was filed as Defect 132286, and the fix will be available in the next Maintenance Release.&lt;br /&gt;
&lt;br /&gt;
As a workaround, you should be able to do the following:&lt;br /&gt;
1.) cut and paste the &amp;quot;GDOT&amp;quot; settings from your DGNLIB into the current DGN file. &lt;br /&gt;
2.) switch to the Survey tab in the Project Explorer and right-click on the Model and select Properties.  Then choose the &amp;quot;GDOT&amp;quot; settings as the Current Settings for the model.&lt;br /&gt;
3.) switch back to the Civil Standards tab and delete the &amp;quot;Settings&amp;quot; now that it is not the Current Settings.&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
