Several times when I use Spiral-curve-spiral tool to create fillet between two arcs of the same direction I felt into problems. Once Civil Geometry is exported to ALG i use check integrity command to verify my alignment and I got Radi Mismatch notice there.
I digged in element properties for that fillet in civil goemtry and discovered that Spiral End or Start value is always set to 0.000 insteda of the value of arcs that being connected with that fillet.
Please take a look at screenshot attached. Something is wrong here. Can anyone has similar problem with civil geometry? Maybe I overlooked something.
Any help is needed.
and here is a check-integrity view which made me investigating these spiral related issue:
Mark Any tool to insert arc-spiral-arc fillet. Forget about exporting to alg and checking horizontal integrity for now. Just chcek civil geometry with Element Properties tool. I ve just started to investigate that issue when spotted errors (radii missmatch) in check-integrity tool for my alg exported from Civil Geometry. I tested few geometry setups: LINE spiral-arc(R1)-spiral ARC(R2) - in this case I used Spiral-Arc-Spiral between Arca an any Element tool. Second spiral should have starting radius equal to R1 and end radius equal to R2 but end radius is equal 0.00. ARC(R1) spiral-arc(R2)-spiral ARC(R3) - accomplished with Ac between elements tool. First spiral should have starting radius=R1, end radius=R2 but I get starting radius=0.00, end radius=R2. The same happens to second spiral. You can see that on a screenshot I attached to my initial post. When I annotate stationing with Tranistion Radius toggled on I can clearly see that spirals will not make transition from R1 to R2.
Moreover. I did another test. I build geometry element by element: I added to a primary arc R1 I added spiral of given length and End Radius R2, then I added an arc R2 to the spiral and then another spiral between Arc R2 and my las arc R3. I was hoping to get the same geometry as by using Spiral-ArcSpiral betwenn arc R1 and aec R2 but I did not.
I am at the dead end with that. It is possible I made a mistake in my way of thinking about geometry, but where?
I am working with PowerInroads 08.11.09.722 thanks.
Best,
Adam
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
What makes me think it may be phisical geometry issue is Element Info. I even dropped Civil Geometry to microstation elements and checked native microstation spiral element - there is a 0.00 value at the end of spiral which is adjacent to an arc.
Unknown said: And lastly, what do you mean by this? "When I annotate stationing with Transition Radius toggled on I can clearly see that spirals will not make transition from R1 to R2."
In Inroads menu go to Geometry>View Geometry>Stationing and there is a tab called Transition Radii it will annotate how R value is changed along the spiral. I use that a lot when choosing ramp locations.
I did more tests: Inroads Geometry tool: free-arc-between elements give different solution than Civil Geometry Spiral-Arc-spiral between elements tool. With CG I get Radii mis-matched info when checking integrity and with Inroads tools everything is just fine.
Please find dgn and alg attached. Initial elements are line and arc R=1970. I added free arc with spirals with Inroads tool (A=1600, R=7000, A=660) then I did the same with Civil Geometry tool (Spiral-Arc-Spiral). as e result I got two different geometries.
CG.zip
when I imported that Inroads geometry to OpenRoads CG i got good values for spiral's start and end R value - both in element info and in xml report. It is different geometry than one created with Arc-spiral-Arc from CG pallete. inroads free curve with spirals was replaced in Civil geometry with spiral arc from element.
