Greetings,
Our client requires us to use the input file utility tool of Coordinate Geometry to create output files for our ROW submittals. In the past few months it seems as if one PC would not be able to create the output file, then another, then another, and now we are down to one PC that can create the file. I have re-installing MicroStation and GeoPAK but have not had any luck. Any ideas?
Thanks!
MS Version 08.11.07.443
GK Version 08.11.07.536
Windows 7
hello, first thing to try is to delete the geopak .rsc files, if you need help with the location please see this post
communities.bentley.com/.../15923.geopak-resource-files-how-to-remove-them-and-why.aspx
then, go to the project directory, specifically the directory where the gpk, input files, and output files reside. (check your user preferences to see where you are pointing to). check for files with the name jxxxxxx.inp (the x's are the job number), delete those files and try again
Answer Verified By: vmorasko71
Nico,
That fixed that issue. Now we are having another one. When one of my users stores a point, it is stored and documented as shown below in COGO but the .ooc file states that it "already exists" and that it was "not stored". Any other Ideas?
t ex
