Can any one help in annotations, i know the procedure to annotate but, my alignment is not selecting for annotation, can any one explain what is the problem, i am using V8i series.
I am using Mx Road V8i (select series 2 ), work flow is designing of alignment, in this annotation are not coming, my sample drawing is placed below.
Can you check if Text have been disable in the file as below. If it has click it to enable it.
