Hello Be Communities.
I have familar with design of super elevation using options of MX. Every time I am facing problems of Conflict points at curve locations. I have tried to edit confilcts points but sometimes it's possible and some neglected.
I am tring to design superelevation using input file method using major and minor options. Any one help me to how write super elevation for design speed of 80 KMPH input file method. If any one provide example file also helpful.
To design superelevation in an input file the design option as highlighted below can be used.
Option 133 will design the superelevation for a specific design speed.
Option 130, 131, 132, 135 and 136 can be used to manually design the superelevation for the scheme.
Option 134 allows superelevation to be transferred to other strings, i.e dual carriageway.
Answer Verified By: Rajashekar Vemula
Best Regards,
Kugan (Account Manager & Technical Adviser on MX and ORD)
