How can I export contours to dwg with lables?
Hi Chris,
I am using MX V8i Select series 3. I need to export contours of a surface with labels to a dwg.
First you will have to generate contours in MXROAD using Analysis > Surface Analysis, once you done with it, contour model will generate. Create a new plan display and display contour model into it. Then after go to File > Export > AutoCAD file.
Unknown said:What product and version are you using?
A litte bit off topic but it has to be asked:
How often is this question asked in the "Road and Site Design" forum? A lot!
It's one of the reason why me an "InRoads User" is not willing to follow the forums threads anymore.
Please split
Frank
