Can any one help to enable the Mx output window,my version is MX roads V8i (select series 2)
First go to MX Menu > View > Output Window. Shortcut Key is Shift + F2. Please refer the attached snapshot for your reference.
If the Output Windows doesn't appear when you enable it then follow the instructions in the wiki article at the link below.
MX Output Window not Displaying
Sir when i gone through the wiki article my Mx window display is showing like this sir, can you help me
