InRoads Survey SS3 (openRoads) Link feature
Working with attempting to use InRoads Survey SS3 (OpenRoads Survey) there seems to be an issue with linking the "Link Survey Feature Definitions" I have attempted to link the xin file several time to my survey.dgnlib but it does not stay. Each time I open or import survey data I need to re browse to my .xin file.
Not sure what is happening but once I make the link it seems to work until I get out of the file. We have the link active features styles defined and it appears to link up each time but this is done through a configuration variable. Actually we only the feature styles and the survey feature definitions are all in the same .xin.
Is there a variabel assosiated with setting the Survey Feature Definitions in a DGNLIB.
