When importing an alignment with General Geometry Import, from a .gpk, one of my advanced users is getting a message stating "Horzontal contains too many elements for civil rule creation." What does this mean and what are the impacts?
PowerGEOPAK SS3 - .722
Hello Joe,
Can you try to use MicroStation settings as shown in the snapshot and then check if still issue persists or not. Please update us.
Purva Lakde
Joe Lukovits
User Since TDP in the 80's,
Vax based Unix Workstations - Interpro32,
from the Intergraph Corp.
Joe, Purva's screenshot is from MX. You're using Geopak (edit: I assumed Joe was the original poster who had said he was running Geopak), so your counterpart to what she's showing won't look quite the same. In your case (and mine), the counterpart shows up before you open the first file of your session. If you have a workspace that is heavily modified by your firm or your client, I'm not sure how useful your response would be.
