Cross Section Sheets - Sheet Label Problem - SS2 Geopak vs SS3 Geopak
Cross Section Sheets - Sheet Label Problem - SS2 Geopak vs SS3 Geopak Begin Station / End Station Annotion Text Size Problem
I am producing the Cross section Sheets When I select the Begin Station / End Station, under the "Sheet Labels" and set the symbology, Specifically the text size, then save an xssl file. If I run the xssl file in Geopak SS2, the font size works properly. If I run the xssl file in Geopak SS3, the font size does not work properly. The font size is too small.
There appears to be a bug in Geopak SS3 concerning the font size.
Below is an example of the xssl file giving me the issue. (a portion of the xssl file)
 SHEET_LABEL_TYPE_6=Begin Station  SHEET_LABEL_NAME_6=BEGSTA  SHEET_LABEL_LABELTEXT_6=Begin Station  SHEET_LABEL_HORIZONTAL_OFFSET_6=31.046715  SHEET_LABEL_VERTICAL_OFFSET_6=3.021650  SHEET_LABEL_PLOT_6=YES   SHEET_LABEL_SYMBOLOGY_LEVEL_NAME_6=GN-SHET-NUMB   SHEET_LABEL_SYMBOLOGY_COLOR_6=0   SHEET_LABEL_SYMBOLOGY_WEIGHT_6=0   SHEET_LABEL_TEXT_HEIGHT_6=1.000000   SHEET_LABEL_TEXT_WIDTH_6=1.000000   SHEET_LABEL_TEXT_SIZE_LOCK_OPTION_6=1   SHEET_LABEL_TEXT_FONT_6=10   SHEET_LABEL_TEXT_JUSTIFY_6=8   SHEET_LABEL_TEXT_SCALE_OPTION_6=0   SHEET_LABEL_TEXT_SCALE_6=1.000000   SHEET_LABEL_TEXT_ANGLE_6=0.000000   SHEET_LABEL_TEXT_FORMAT_PREFIX_6=   SHEET_LABEL_TEXT_FORMAT_SUFFIX_6=  SHEET_LABEL_TYPE_7=End Station  SHEET_LABEL_NAME_7=ENDSTA  SHEET_LABEL_LABELTEXT_7=End Station  SHEET_LABEL_HORIZONTAL_OFFSET_7=32.883967  SHEET_LABEL_VERTICAL_OFFSET_7=3.021650  SHEET_LABEL_PLOT_7=YES   SHEET_LABEL_SYMBOLOGY_LEVEL_NAME_7=GN-SHET-NUMB   SHEET_LABEL_SYMBOLOGY_COLOR_7=0   SHEET_LABEL_SYMBOLOGY_WEIGHT_7=0   SHEET_LABEL_TEXT_HEIGHT_7=1.000000   SHEET_LABEL_TEXT_WIDTH_7=1.000000   SHEET_LABEL_TEXT_SIZE_LOCK_OPTION_7=1   SHEET_LABEL_TEXT_FONT_7=10   SHEET_LABEL_TEXT_JUSTIFY_7=8   SHEET_LABEL_TEXT_SCALE_OPTION_7=0   SHEET_LABEL_TEXT_SCALE_7=1.000000   SHEET_LABEL_TEXT_ANGLE_7=0.000000   SHEET_LABEL_TEXT_FORMAT_PREFIX_7=   SHEET_LABEL_TEXT_FORMAT_SUFFIX_7=
