I do not get a right-click pop-up menu when I am in the dynamic cross sections, how can I get that menu to appear? I'm running Power GEOPAK SS3 08.11.09.722.
If you give a right click then hold it for a couple second, one or two times, in the other view that your are modeling the cross section profile, it should appear the
MENU with :
> Edit Station
>Place Temporary Dimension
>Remove all temporary dimension....and others options.
If does not appear the menu what happens in the view
Answer Verified By: Katie Johnson
