Hello Community :)
I've created an interface input with changing width of one of a middle element from 5.0 to 1.0 [m].MX says "Invalid combination of data fields". Where have I mistaken? Below part of input:
INTERFAC,MAP TRIA,A1 SLOPES259,INTI260,1=MC10,2=IW10,3=IX10,4=-12,5=416495,8=418000261,1=IGN ,2=ES11,3=RP10,4=5,5=0.50,6=,7=-0.46261,1=IGN ,2=RP10,3=RU10,4=5,5=0.50,6=,7=-0.14261,1=IGN ,2=RU10,3=RP11,4=5,5=0.50,6=,7=+0.14261,1=IGN ,2=RP11,3=IA10,4=5,5=0.50,6=,7=+0.46261,1=IGN ,2=IA10,3=IA11,4=5,5=5.00,6=,7=+0.05261,1=TX00,2=IA11,3= ,4=5,5= ,6=,7=+0.66667262,1=TX00,2=ES11,3= ,4=5,5= ,6=,7=-0.66667 260,1=MC10,2=IW10,3=IX10,4=-12,5=418000,8=418100 261,1=IGN ,2=ES11,3=RP10,4=5,5=0.50,6=,7=-0.46 261,1=IGN ,2=RP10,3=RU10,4=5,5=0.50,6=,7=-0.14 261,1=IGN ,2=RU10,3=RP11,4=5,5=0.50,6=,7=+0.14 261,1=IGN ,2=RP11,3=IA10,4=5,5=0.50,6=,7=+0.46 261,1=IGN ,2=IA10,3=IA11,4=5,5=5.00,6=,7=+0.05 ,9=1.00,10=+0.05 261,1=TX00,2=IA11,3= ,4=5,5= ,6=,7=+0.66667 262,1=TX00,2=ES11,3= ,4=5,5= ,6=,7=-0.66667260,1=MC10,2=IW10,3=IX10,4=-12,5=418100,8=442505261,1=IGN ,2=ES11,3=RP10,4=5,5=0.50,6=,7=-0.46261,1=IGN ,2=RP10,3=RU10,4=5,5=0.50,6=,7=-0.14261,1=IGN ,2=RU10,3=RP11,4=5,5=0.50,6=,7=+0.14261,1=IGN ,2=RP11,3=IA10,4=5,5=0.50,6=,7=+0.46261,1=IGN ,2=IA10,3=IA11,4=5,5=1.00,6=,7=+0.05261,1=TX00,2=IA11,3= ,4=5,5= ,6=,7=+0.66667262,1=TX00,2=ES11,3= ,4=5,5= ,6=,7=-0.66667263
Best regardsAleksander Zamorski
Thanks, works fine - the problem was also with missing "259,INTI" before every 260/261/262/263 sentence...
RegardsAlekesander Zamorski
Mark:
ie in MX user manual in 261/262 option: "Field 9 - Element width at end SPRD as defined in the immediately preceding 260 record or level to which the interface is to be calculated if LEVL is coded in field 1.If LEVL is specified in field 1 then field 9 contains the level at which the interface is to be found."
RegardsAleksander Zamorski
Once more I've encountered this error (E029 Invalid combination of data fields). It works fine with constant width of 5.0 [m].
Sections in "A1 SECTIONS" for multi-strata are:R - ditch bottom (flat line)T/U - existing ground
INTERFAC,A1 SECTIONS,A1 SLOPES259,INTI260,1=MC10,2=IN1i,3=IN1i,4=+11,5=417195,8=417200261,1=R ,2=ES1J,3=RT1i,4=5, ,6=,7=-0.66667261,1=IGNR,2=RT1i,3=RV1i,4=5,5=0.2 ,6=,7=+0.0261,1=IGNR,2=RV1i,3=RT1J,4=5,5=0.2 ,6=,7=+0.0261,1=IGNR,2=RT1J,3=IS1i,4=5,5=0.75,6=,7=+0.66667261,1=T ,2=IS1i,3=IS1J,4=5,5= ,6=,7=+0.66667261,1=IGN ,2= ,3=IS1K,4=5,5=0.00,6=,7=+0.00261,1=IGN ,2=IS1K,3=IS1L,4=5,5=5.00,6=,7=+0.05,9=4.00261,1=U ,2=IS1L,3= ,4=5,5= ,6=,7=-0.66667261,1=U ,2=IS1L,3= ,4=5,5= ,6=,7=+0.66667263999
I have no idea how to make it correct ...
Typical section for interface below:
RegardsAleksnader Zamorski
