Problem creating a tin file – Different results using Select Series 2 vs Select Series 3
Geopak_Support_2015_01_19.zipI have a dgn containing graphic triangles.
When I create a new tin file using “Extract Graphic Triangles” I get different results when using Select Series 2 vs Select Series 3 Geopak.
SS2 produces the correct resulting tin file.
I have attached a data set.
The data set contains a DGN file with graphic triangles.
Also SS2 and SS3 dat file and in files
Please compare the graphic triangles from the two tin files in the area circled on level “Problem_Area”
