How can I get rid of stray lines in the cross sections at template transitions?
I am trying to use 2 templates in my geopak SS3 corridor. When I insert my second template, I see stray lines in my dynamic cross sections. These may be related to the transition between the two templates, but I am trying to insert my second template without a transition. I don't know how to control if and how the templates connect as there doesn't seem to be a transition inserted anywhere when I review my Corridor Objects.
Are there any tutorials about template transitions in SS3?
(Power GEOAPK V8i, Version 08.11.09.722)
In this figure I have only a single template drop
This figure is the same station as above, but after I have inserted a second template drop 1ft beyond this station. I indicated 0 minimum transition distance.
