I am trying to create an ICM from a corridor and I cannot because the program crashes before the ICM is complete. I would like to create the ICM so that I can import into Trimble Business Center.
Steps I took to create the ICM....
1. Create a terrain model from existing .tin file.
2. Create an alignment and profile.
3. Create a corridor.dgn file and reference terrain model and aligment and profile files.
4. Create a corridor using a DOT supplied template.
5. Use the Create ICM tool under the Model Interoperability task
6. Select the option to Include Design Models
7. The process starts but then immediately the error dialog pops up
Then MicroStation\Geopak SS4 crashes or closes. Am I going this correctly or have I missed a step.
TIA
MS V8i SS3 08.11.09.655 - Geopak Suite V8i SS4 08.11.09.789
I hope this answers your question.....If not please let me know.
I was having another issue that is directly related to this issue. The post is here - http://communities.bentley.com/products/road___site_design/f/5922/p/104340/313382#313382
Answer Verified By: Sean Keene
