I noticed an issue with end conditions not tying into the existing ground line drawn in cross section cells. The problem occurred at several cross section and the error varied between 0.01' to upwards of 2'. After troubleshooting, it was noticed that there are differences between the TIN file and the DTM file. The DTM file was creating by converting the TIN surface into a DTM surface readable by Roadway Designer. The existing ground lines in the cross section cells were drawn in using a TIN. If I cut existing ground line using the DTM created the the same TIN file there are differences between the two. The proposed DTM model then ties perfectly into the existing ground surface in a DTM format, but this file is no longer accurate as it does not triangulate in the same way as the TIN file, creating erroneous triangles and causing differences of elevation up to 2'.
Any ideas why these two formats of a surface would not be identical?
08.11.07.619
To clarify, it appears in the picture I posted above that the difference is a very consistent shift, but it is not. The majority of the surface is very accurate, but occasional areas will vary sometimes significantly. It almost appears that the way the DTM triangulates is different from the TIN. See the screenshot below. The yellow dots represent vertex points along the DTM surface. The two exterior vertex points are the only two vertex points for this area between the TIN surface.
The first screenshot showing the proposed DTM is cut at an exact station the template is applied. The issue is not with the proposed model and interpolation between template drops, but rather with the existing ground surface. We have a TIN file of existing ground surface that is required to be converted to a DTM for use in Roadway Designer. During this conversion, I believe the DTM is triangulating the data differently than the TIN . It was because the proposed DTM was consistently failing to tie into the existing ground TIN that I decided to see if it will tie into the existing ground DTM that Roadway Designer uses. It fixed the issue of the proposed DTM tying into existing surface, but now I have an existing ground DTM surface that no longer replicates the existing ground TIN surface. Certainly, I cannot trust the DTM surface if I am seeing differences in elevation of 2', but I cannot use the TIN because Roadway Designer requires a DTM.
DTM
TIN
