GEOAPK-IMPORT/EXPORT LAT-LONG POINTS
I am starting a new project next week using Power Geopak V8i SS2.
I will be given some point data from a cell phone collected in the field in lat-long format.  From perusing the discussion groups, it appears the method for importing/exporting lat-long data is by selecting: Tools->Dimensions->XYZ Text->Import Coordinates and Export Coordinates.  Can someone confirm if the above workflow is correct for importing/exporting lat-long point data into Power Geopak v8i SS2.
  • This tool if to EXPORT/ IMPORT COORDINATES , these are the formats you will get
    The following are the available Import options:
    Import Order
    Points XYX YXZ
    Text XYZ\ YXZ
    TXYZ (Text, X coord, Y coord, Z coord)
    TYXZ (Text, Y coord, X coord, Z coord)
    XYZT (X coord, Y coord, Z coord, Text)
    YXZT (Y coord, X coord, Z coord, Text)
    Cell XYZ YXZ
    CXYZ (Cell, X coord, Y coord, Z coord)
    CYXZ (Cell, Y coord, X coord, Z coord)
    XYZC (X coord, Y coord, Z coord, Cell)
    YXZC (Y coord, X coord, Z coord, Cell)
    Answer Verified By: CADTech1
