I am using Power Geopak V8i SS2.
I am trying to convert GPK geometry points to lat-long coordinate format, written to an external file. My workflow is this: Select Survey->Geometry->Conversions->Geodetic->select Source Coordinate System and Target Coordinate System->File pull-down menu->Output to ASCII file and I select GPK File (center button). See Image below. However, I am selecting the job number as shown in image (per help menu), but no data appears in window. I have tested my project connections by opening Navigator and viewing the data, but do not see any problems with data connections in project. When I select Convert in below dialog, my computer locks-up or at least goes into indefinite processing. I have to assume this is because the data is not being read in the gpk for some reason. If I select "Get Points from Microstation Selection" and select on screen, I do not get any response. So I have to ask, why is the data not showing-up in the window?
Answer Verified By: CADTech1
