SURVEY question
I am using Power Geopak V8i SS2.
I am trying to convert GPK geometry points to lat-long coordinate format, written to an external file.  My workflow is this: Select Survey->Geometry->Conversions->Geodetic->select Source Coordinate System and Target Coordinate System->File pull-down menu->Output to ASCII file and I select GPK File (center button).  See Image below.  However, I am selecting the job number as shown in image (per help menu), but no data appears in window.  So I have to ask, why is the data not showing-up in the window?
