overlay template design
Hello everyone Can any body help me to design a overlay template of 2 lane  in openroads SS4 with following conditions/cases
1) If existing road is not symmetrical to proposed center line or existing zig zag , how the point control of both the ex. carriageway edges will be act, it violates the requirement where ex. carriageway leaves the proposed carriageway.
2) In any case the area of  existing carriageway whether it is riding LHS , RHS or symmetric to Proposed Center line should be considered for milling/overlay ( only if when it comes under proposed area of carriageway) should be applied on that part and for rest it should be designed as new pavements.
Deepak Rawat
  • Hi Deepak,
    When you apply point control, you are overriding the template geometry in design corridor and each point can follow only one controlling feature in one corridor. A better way to do this will be to create the template in such a way that it caters to all possible scenarios of Overlay and Widening. A possible solution is shown in the attached images. Instead of point control, Horizontal Feature Constraint option is used within template to identify and follow existing road edges. Display rules are set for all the components and hence you can see that a different component gets applied for any changed scenario.
Reply
  • Hi Deepak,
