GEOPAK-IMPORT COORDINATES
I am using Geopak V8i SS2.
I have imported some points as boreholes which match the geometry I would expect, as far as their placement in my dgn file.  Then I also imported them using the Tools->Dimensions->XYZ Text->Import Coordinates->fill-in the dialog with appropriate settings->then Process.  However, the points imported in a very different location.  Why would they not place correctly in my dgn file using the Import Coordinate Tools?
