I am working on cutting cross sections for a new 4 lane roadway. The standard cross section borders go from 150' left of baseline to 150' right. Being that this is a new roadway, the proposed surface sometimes goes beyond these limits, so we'll need a matchline above to show the rest of the section. Is there some way to do this when cutting them? Or at least a way to tell the cross section command that if the proposed surface is wider than 150' left or right to only put one section on that sheet so we can add the matchline above it?
MicroStation SS3 V 08.11.09.357 and Inroads SS2 V 08.11.07.566
Thanks!
Is there a way to control it so the areas left and right of the -150' to 150' range show up on either the left or right above it? When I tried this I think I went -200' to 200' in the area I needed and it started the cross section at -200', went past the right border of the sheet, and then put the remainder of the right side of the cross section above on the left. I would like to keep the centerline of the cross section in the center of the page and only have the ends beyond the 150' show up above to the left or right as applicable Is this possible?
Answer Verified By: Joseph Rusiewicz
