I am using Power InRoads V8i (Select Series 4) V08.11.09.789.
When I set the symbology for my utilities, using the Create Utility tools and then the Edit Utility tool to edit the utility details, I am unable to either Save or Save As the modified data as a Preference as I get the message 'Preference not Found'.
This means that each time I opeen InRoads I have to update the Utilities symbology if I am doing anything which involes refreshing my Utility data i.e. upating the drainage profile. Does anyone else have this problem and any suggestions how to rectify matters?
I'm having the same problem with InRoads suite.
Has this been fixed yet?
I'm using Power InRoads Select Series 4.
Thanks for the info.
Description:Microsoft no longer delivers the MSXML4.DLL parser in Windows 7 or Windows 10. This parser is required for the InRoads product to view the XML information. Therefore, since they are still required as a dependency for the InRoads program to function properly, the files have to be downloaded and installed by the user. If the files have do not exist on the machine from a previous installation of InRoads, users may see this problem. This is mainly an issue on new installs of the product on new machines which don't have the MSXML4 parsers.
Solution:Download and install the "msxml.msi" file from the Microsoft website. - http://www.microsoft.com/en-us/download/details.aspx?id=15697
I saved this a few years back.
