Hello All,
We have an InRoads SS2 surface and want to generate stake out points from the surface.
Along the breaklines, we want critical points (end points, high/low points, change of direction), plus at an interval (let's say every 10m).
Then, across the surface, we'd like a grid of points at 5mx5m grid intervals.
We need to create a table of these set out (stake out) points and show the points, with their point numbers, in plan view.
How is this achieved in InRoads?
Hi Jeff,
not a bad thought ;-)
I've found a method that saves a few steps - well, for what I'm looking to achieve anyway.
Use whatever MicroStation Point tools you like to place points at every location you wish to generate a stake out point.
I used a combination of:
Once you have a point at each desired location, select them all.
So, with these steps, you now have them all in COGO.
Then use the Geometry>View Geometry>Horizontal Annotation to display the Point (using a symbol "+") and Annotate the Point Number. So that gets the Point numbers drawn into the DGN.
Creating the table still isn't great. One method I just found was to create the table using the XML reports - as you said (I used the List Coordinates Report). I then printed that report to a PDF. I set the page size to an A1 so I didn't get a multiple page PDF generated. That gave me pretty good result with regards to the formatting. I then attached the PDF as a raster image.
Doesn't look too bad when I plot using IPLOT (which is out standard method).
Thanks for all you tips and assistance...
Seriously. I cannot believe its this difficult.
