I use Microstation V8i Select series 2 and GEOPAK. I've created a TIN from survey data, but the data shots in a few small areas are not close enough, there fore they didn't triangulate between them. I know I could redo the processing and set the tolerance farther, but the TIN has already had quite a bit of manual cleaning up, so I don't want to redo anything. Is there a way to manually have the software triangulate between theses points?
