How do I unlock entry dialog to be able to graphically select location with "Locate Station via Datapoint"
This is probably simple, but when using the "Locate Station via Datapoint" command in SS3 dynamic cross section view, I can only key in the location, not graphically select.
Parents Reply
  • Thanks,
    For some reason the dialog box was not visible when I was having this trouble, I could only see the data entry box that follows the cursor. Later I did see the dialog box with the checkbox and found that I could control it that way as you describe. I have no idea why I can sometimes see and sometimes not see that dialog box. Is there any keystroke pattern that can unlock that entry if the dialog box with the checkbox disappears?
