Loading IR SS2 changes MS GUI, Why?
If I load InRoads SS2 from the application menu my Microstation GUI changes immediately, open and docked toolbars getting switch off.
Why and how can I avoid this?
Parents Reply
  • The standard Microstation toolbars get switched off, I can not see them and have to open and dock them again. It appears if I'm working in a second instance of Microstation while the first one is running another dgn.
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Autodesk Civil 3D , Esri ArcGIS, VertiGIS: in previous days : Bentley MS V4 - V8i, GeoGraphics, Bentley Map V8i, InRoads,  HHK Geograf, IBr DAVID] :  Dev: [C, C++, .NET, Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
