I have a profile that I've created that is a little odd but it's what we needed. The stationing is along the center of the road but the existing ground line and proposed gutter elevations are along a feature. I have these annotated in the profile to show the elevations using the stationing along the centerline so that worked as I needed. Now they would like me to give them a report of those numbers but I can't seem to be able to find an xml report that will give me the information I need. I was wondering if anyone has anything that I could use. If you do a surface report, it does give you the option of picking the feature you want but it doesn't have anywhere to tell it what alignment to use or interval (50').
Answer Verified By: Marc Freshley
