Microstation V8i SS3 8.11.09.608, Geopak SS3 .722
When I open a fresh instance of Microstation. I select the file to work in. All my tools appear and even Civil AccuDraw comes up. And then this error.
************** Exception Text ************** System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.NullReferenceException: Object reference not set to an instance of an object. at System.Windows.Forms.ListControl.set_DataSource(Object value) at System.Windows.Forms.ComboBox.set_DataSource(Object value) at Bentley.DesignLinksApp.ProjectDialog.ReloadProjectPicker(Boolean setActiveProject) at Bentley.DesignLinksApp.DesignLinksApp.TreeListSourceChanged(Boolean SynchWithActiveProject) at Bentley.DesignLinksApp.DesignLinksApp.OnNewDesignFile(AddIn addIn, NewDesignFileEventArgs __unnamed001) at Bentley.MicroStation.AddIn.NewDesignFileEventHandler.Invoke(AddIn sender, NewDesignFileEventArgs eventArgs) --- End of inner exception stack trace --- at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Delegate.DynamicInvokeImpl(Object[] args) at Bentley.Internal.MicroStation.EventHandlerSet.Fire(Object eventKey, Object sender, EventArgs e) at Bentley.MicroStation.AddIn.raise_NewDesignFileEvent(AddIn sender, NewDesignFileEventArgs eventArgs) at Bentley.MicroStation.AddIn.generateNewDesignFileEvent(SByte* filenameP, Int32 when) at Bentley.Internal.MicroStation.CoreHook.DispatchNoHandler(UInt32* argStack, UInt32 mysp, IntPtr pFunc) at Bentley.Internal.MicroStation.CoreHook.Dispatch(UInt32* argStack, UInt32 mysp, IntPtr pFunc)
8625.Exception.log, 4405.msdebug.txt
When I click continue, of course the automatic reporting windows come up. And then if I click to ignore, it continues to work normally.
This began just this morning. When I left my computer last night it seemed to be fine.
I've found that this error is raised each time I open a different file.
