Rotate 5 degrees stopped working - But Only in affected files?
Weird issue.  We have several files that have suddenly stopped responding to the rotate 5 degrees view command.  Rotate to element still works, as does Rotate to North.  Any idea what setting has gotten fouled up?  The rotate 5 is still working in some other drawings.  Thanks, Michael
Microstation V8i SS2
  • Just realized this is a GDOT View menu, customized by Georgia DOT and included in their workspace. Also noticed that the 'prompt' line displays the message " No rotation specified" in the affected files. However, in the normal files, it shows "Custom Tool > Select view" . Seems as though some setting has become corrupted or inadvertently been changed from 5 degrees. Thanks in advance for the help in troubleshooting it.
